Hosting 3D Content
Extract the contents of Cesium-ion-3D-Tiling-Pipeline.zip
. The main executable can be found in the extracted directory under bin/asset-server
Run this command in the extracted directory:
bin/asset-server -d Data
This will start the server on port 8002
and serve all 3D Tiles, terrain and imagery in the Data
directory. You can also specify multiple directories to serve:
bin/asset-server -d Directory1 Directory2 Directory3
All directories specified are also served statically at http://localhost:8002/static/<directoryName>
. This allows you to serve files such as glTF models, GeoJSON files or any other content.
Below are examples for serving different kinds of content.
3D Tiles from .3dtiles
database file
A 3D Tiles database file placed at Data/3DTileset.3dtiles
is accessible at http://localhost:8002/3DTileset/tileset.json
3D Tiles from a pile of files and directories
A 3D Tileset directory placed at Data/3DTilesetFiles
is accessible at http://localhost:8002/static/Data/3DTilesetFiles/tileset.json
Terrain from .terraindb
database file
A terrain database file placed at Data/WorldTerrain.terraindb
is accessible at http://localhost:8002/WorldTerrain
Imagery tileset from a directory of tiles
An Imagery tileset placed at Data/ImageryTileset
is accessible at http://localhost:8002/static/Data/ImageryTileset
Other files
Any other files (such as glTF models, GeoJSON files etc) in the Data
are served statically at http://localhost:8002/static/Data/path/to/file
Below is a full list of command line arguments to configure the server.
Flag | Description | Default |
--help , -h | Display help message. | |
--version , -v | Display version number. | |
--data , -d | Path to one or more directories containing .terraindb , .3dtiles , imagery or 3D Tiles. | Current directory. |
--port | Set the port to listen on. | 8002 |
This section describes how to set up CesiumJS and stream your 3D content in the browser.
Setup
Install Node.js (version 8.9.0 or higher), then download and extract the CesiumJS library.
Open up a terminal window in the cesium
directory and install the required dependencies:
npm install
Run the build process:
npm run minifyRelease
Finally, start the server to serve CesiumJS:
npm run start
Open the URL http://localhost:8080/Apps/HelloWorld.html to run the simple Hello World example.
Adding 3D Tiles
To add 3D Tiles from a .3dtiles
file to the Hello World demo, open the file cesium/Apps/HelloWorld.html
in any code editor. Change the code between the <body>
tags to:
<body>
<script>
var tileset = viewer.scene.primitives.add(new Cesium.Cesium3DTileset({
url : 'http://localhost:8002/3DTileset/tileset.json', // URL from `Starting the Server` section.
viewer.zoomTo(tileset);
</script>
</body>
Make sure to use the link to your local server in the url
field above. Now if you re-run the Hello World demo you should see your 3D Tiles streamed from your local server and visualized in your browser!
Adding Imagery
To add imagery tiles to the Hello World demo, open the file cesium/Apps/HelloWorld.html
tags to:
<body>
<script>
var viewer = new Cesium.Viewer('cesiumContainer', {
imageryProvider : new Cesium.TileMapServiceImageryProvider({
url : 'http://localhost:8002/static/Data/ImageryTileset' // URL from `Starting the Server` section
baseLayerPicker : false
</script>
</body>
This will load TMS imagery from Data/ImageryTileset
and turn off the base layer.
Adding Terrain
To add terrain to the Hello World demo, open the file cesium/Apps/HelloWorld.html
tags to:
<body>
<script>
terrainProvider : new Cesium.CesiumTerrainProvider({
url : 'http://localhost:8002/WorldTerrain', // URL from `Starting the Server` section
</script>
</body>
This will serve terrain from Data/WorldTerrain.terraindb
Check out the CesiumJS tutorials for more in-depth information.
